I have a problem with the drivers side rear door - it won't unlock
The silver lock button on the door does not raise when the central locking button is pressed on the key fob. I cannot open the door by operating the interior door handle either.
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Does the door unlock and open with the key and outside handle? If it does then you have most likely broken the cable that runs from the interior door handle to the lock mechanism.
You can do a search in the X308 section for door cable. There are plenty of step by step instructions for changing it. Its about $80.00 from Jagbits.
Roll the window down and PULL UP on the knob (hard). Maybe while operating the 'UNLOCK' keyfob button or have some work the locks from the driver's door.
Remove the door trim panel and lube all the latch linkage.
You will have to get aggressive with it.
So I have managed to pull the lock button up by pulling the interior door handle, which raises the silver button just proud of the collar, however the door remains steadfastly locked!
When I let go of the interior handle, the button returns to the locked position as if it were sprung.
Any other suggestions?
Think I'm gonna have to take it to my local Jag specialist.
Were you able to get this resolved? I have the same exact issue with my 2003 S-type for a week now, except my FOB also quit working AGAIN about a month ago.
So I took it in to my local garage, they stripped it down and opened it for me.
The solenoid that drives the door lock has given up the ghost on mine and needs replacing.
Hi Bob I have the same problem but it's the drivers door and it won't open with the key or from the inside, any suggestion on what I can do please would be appreciated. X Type 03
Also if you add the year,model,milage and engine size in your signature. This will benefit you over & over again when asking for help as it immediately shows any member what model / year you are asking about.
Hope you get it resolved and good luck.
Take care.
Andy
Jim, I have a 2002 XJ8 With the exact same problem. I cannot figure out how to get the door panel removed from inside the vehicle. Any advice from the forum would be greatly appreciated.
‘Monty Peek
