Drivers door window not working
Unplugging anything on these cars with the battery connected can easily introduce gremlins. When I replaced the cable on my VDP, I had odd problems with the windows as well. I did 2 things; first I took electronic cleaner to each connector in the door to make sure the connections were good (and no pins were pushed or bent). I also did a hard reset/reboot of the electrical system (disconnect battery leads from the car and briefly touch them together). My windows worked fine after I did this.
If the system was working fine before you started the project, it is very likely related to something you did or touched. Eliminate the easy and cheap fixes before you assume it is the motor.
hafren
08-30-2023 03:42 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
msdg137
09-16-2015 06:24 AM
