Drivers door won't open
Hi all, just replaced a broken drivers door outside handle, reassembled everything, closed the door, and now it won't open at all with either handle. What gives? I did manage to pull the door card off from the inside to get some access. Not sure what to do next to get the door unlatched. Ideas? It's a 03 XJR.
Thanks!
Kevin
Milwaukee, WI
Thanks!
Kevin
Milwaukee, WI
That's what its sounding like.
Take a look at this, skip to about 6:20 and you'll see where he has to use a screwdrive to dislodge the lock actuator. Just to see if this is your issue.
Other than that, you need to get ahold of the mechanism for the latch release and fart around with it until you win the game. I suggest spraying the latch lightly with some dry silicone lube, it may help it release.
Sharrieff
07-09-2013 09:34 AM
