Drivers Heated Seat 03 XJ8
Ok, so I have read every post I Can find concerning heated seats (Yes I can live without it but why?) I have put my fingers on the relay under the drivers seat when turning the seat heater on and the relay kicks in without issue, but the seat doesn't heat up. So at this point I figure it is the heat element, does anyone have removal instructions to get to the element or is this something everyone sends to the shop? I prefer to fix things myself.
Guest
Posts: n/a
RE: Drivers Heated Seat 03 XJ8
My 03 XJR doesn't seem to get the seats very warm either. I see the manual says they are thermostatically controlled. I can't imagine all 4 seat heaters are weak. With the car being in Miami they weren't probably used much. I wonder if there is a way to change the thermostat setting. You can feel the seat get slightly warm but nothing like the three positions switch onthe BMW. A hot seat is required equipment this time of year
I know this is an older post, but it does ask a similar question I have about the heat output of the seats. The other day I went with my friend to pick some christmas gifts up, and we took his 2001 BMW 750iL. I tried his heated seats, and they were lovely and warm, and really made my back feel better (I have Siatica). When I got back in my XJ my seat was no where near as warm, and neither is the passenger's.
Is there a way to adjust the thermostat? Or is there other options for improving the heat output of these seats? Ta Fellas, S.
There are 2 pads (I assume) as my seat base and seat back both get really toasty. So does the passenger side. I can state categorically that the seat heaters in a '00 XJR are way more powerful than the seat heaters in a '92 XJS Conv as I get constant complaints from my girlfriend that the XJS doesn't get warm enough :-)
Agree with other posters comments that they take a while to get up to temp, maybe 5 minutes, and they do seem to go off after a while, but usually you are already roasting by this stage.
My XJR is a California car and I had seen other posts that stated the seats wouldn't heat up if the outside temp was greater than a certain value, but I've always been able to turn mine on, even on a really hot day here. Sounds like there is some "variability" in the XJ heated seat system, but then it wouldn't be any fun if they were all the same, would it ?!
