Drivers mirror turns "in" overnight
So this just started happening a few days ago. When I go out to my car in the morning the mirror (not the mirror housing) has moved and is pointed "in" as far as it will move. Since they are power mirrors I simple change the position but what is causing the mirror to move? Its really, really wierd...?
I believe it to be an auto dip feature. I hope to be corrected if mistaken, but I know a lot of high end cars carry such a feature that dips the side view mirrors down and in to help aid in parellel parking when going into reverse, but suspect it would revert back to its original position once put in drive.
As you said it only works with reverse engaged, and reverts to normal position when taken out of reverse.
But then again my car is UK spec, it may be different on US spec models.
I would imagine it must be programmed to that position, and goes there when you unlock the car. I would try re-programming it. Other than that, I have no idea because U.S. spec cars don't have the "dip" feature on the drivers (left) side, just on the right side, but only when you are in reverse, and press the mirror adjust switch.
![Icon Arrow](https://www.jaguarforums.com/forum/images/smilies/icon_arrow.gif)
I agree with Scott. Try to reprogram it. Use a different program button. Reset the seats and the mirrors to the right position. Then hit memory. That sets the seats, steering wheel and mirrors. Then with the car in reverse, program the right mirror for backing up. instructions are in the owners manual. Oops, in your case, the left mirror for backing up!
