Drivers Seat Not Working.
Received 1,813 Likes
In Blacksburg there's Carguts, its recycle yard that's pretty good on prices. You can find them here... Car-Part.com--Used Auto Parts Market ...and give them a call. They get busy, so be patient, but prices are excellent.
Check with Col Sanderz also in the Marketplace, he's doing a clean out sale... https://www.jaguarforums.com/forum/p...an-out-199893/
omgimali (05-28-2018)
It should just be a motor replacement attached to your seat carriage until you check for sure. Look here, Dave may have one.... https://shop.everydayxj.com/Default.asp
No, you need to determine your bad one (get the part number) and replace it. Without pulling the seat out, remove the four corner nuts holding the rails (if you can, tilt the upper back forward all the way) tilt it back into the back seat and either remove the rail assembly from the seat or try to determine the issue where it sits. If it smelled as bad as you stated, you should be able to find it rather quickly.
omgimali (08-14-2018)
Here's a link to review... JagRepair.com - Jaguar Repair Information Resource
Here's the cars electrical schematic... http://www.jagrepair.com/images/Auto.../jagxj1998.pdf
xjrwithproblems
05-21-2014 03:13 PM
denisecdb
04-10-2012 11:08 PM
