Driving in town
Ah, understood. I guess you definitely don't need it. And maybe, it is less wear and tear to avoid the extra gear. I always just allow my car to handle it for me. I love how smooth it shifts, so I hardly notice it.
With all the reports of transmission problems, I was a little nervous when I bought it, but I've found this transmission to be quite robust. I did of course change the fluid first thing after buying it.
or even performance.
I am currently trying a tankful in Normal mode because of gas consumption.
But, 90 percent is city driving in traffic
Performance wise. Major Difference if you stomp on it. Both starting in 1st and cruising at 50 mph, then stomping it. Then it's a Beast
I've heard some people that prefer Sport Mode daily driving, but I personally prefer Normal Mode. 90% of the time I'm a laid back driver. I've got Sport Mode and a Blower for the other 10%.
Wow,
My city is more like 11.5 in normal.
4.0 engine.
4.0 engine.
Shift quality is most noticable when starting out. If I start in Sport mode, it starts in 1st gear. The shift from 1st to 2nd is slightly jumpier. If I'm on the gas, every gear is jumpier. In Normal Mode, I get 17.5 - 22 MPG. City vs Highway.
I hate to admit it, but I run 32lbs all around. I don't know why, but that's what I've always done with all my vehicles (Except Motorcycles). Also, keep in mind that I live in a small town, so not a lot of traffic lights, and I stay in Normal Mode, not Sport. Like I said, I'm easy on the throttle 90% of the time. Once in a while, I stomp it just to hear the blower whine, but not too often. I run 91 octane fuel all the time (otherwise, it sputters a little). I just went out and checked, and I have 17.6 MPG average and 29 MPH average (used about 1/2 tank). That does include a little highway driving. How does the average MPH compare with yours?
I run GoodYear Eagle GT's 255/40ZR18. They are a bit noisy, but I love the ride, looks, and handling. Also, quite good in the snow. With a rating of 400 AA A, I'm hoping to get a few miles out of them too.
32 PSI all around
Clocked 20 mpg on a new tank for pure highway @ 70-80 for 300 miles tonight. 87 octane.
Congested urban is about 12 mpg on 94 octane, same style of driving as you.
The return trip will be at 36 psi.
Currently on 245/40-18 Toyo winters installed by PO.
32 PSI all around
32 PSI all around
On a trip to Reno NV, including going over the Summits etc, I got 23.5 one time. That was on my old tires, just about worn all the way out.
I know it's a VERY small difference, but my tires are slightly taller (25.6 - 25.7). Do you think that's enough to make the difference? Not sure how that calculates out to mileage. PS: My normal Highway crusing speed is 70MPH.
BUT, rolling resistance matters. That's why the old tires did so well.
Ah, that makes sense. Now, I've never done mileage calculations manually, always read the computer. But, since my Speedo seems to be dead on accurate (checked against GPS), the computer should also be accurate?
