DSC not Available message is on
Hi everybody,
i have read a lot about this message but all what i have read was about having the DSC not available and the abs light is on.
in my XJ6m,2006. 77,000 km, I am only having the DSC message with the sliding car icon only. No abs light is on.
yesterday i managed to remove the rear speed sensors, cleaned then and placed them back but that would not resolve the problem. i couldn't locate the front one.
i have sent the car to Jaguar dealer but he suggest to change the ABS modulator which is extremely expensive.
i will appreciate in assistance in resolving this issue. any help please!!
Hi everybody,
You have cleaned the rear sensors...now you will need to clean the front sensors which are on the hubs behind the disc brake.
It's rare on these to have the ABS unit replaced....I think they are leading you up the garden path ;o)
What condition is your battery?
Posts and connections clean and good?
First thing to do is get any codes read.
First of all, thank you for your quick reply.
I just came back from the Jaguar agency, and i get to know that the previous owner has changed the ABS module with an older used module that does not support the DSC function, and That is exactly why I am having the (DSC not available) message with no ABS light on.
The problem now is that i cant find the original ABS module number so i can search for a similar one. the number i got from the agency is ((JAC2C 35613)) which is dealer part number not part number which ends with AD or AB or AC.
please need help.
Horrible news.
please need help.
please need help.
The correct type should be found at a number of dismantlers or e-bay.
Raaouf
You should be posting your issues about your 2006 XJ6 in the (X350 & 358) section of the forum.
Look at this other thread on your issue and how they resolved it:
https://www.jaguarforums.com/forum/x...solved-115629/
Jim Lombardi
Jim Lombardi
goges
10-05-2015 04:53 PM
