The eagle (4.2) has landed;)
Received 9,011 Likes
Hey Adam.....please do a write up for the site if you can.
Before, during and after pics c/w tools used, prices paid and time taken would be great too as well as any tips hints or tricks you gathered along the way
Anything you can do would be great......I'd be interested to se how you get on for sure.
Good luck with it
Adam, you might have got lucky on the non plastic bits, it looks worse than it is?
Are you going to use a 4.0 engine harness and injectors? I'd be ordering all new hoses and gaskets. Have you got a late model throttle body you can use?
How far are you going to strip the engine down? To be 100% sure it'll fire first time, it might require all engine sensors replacing, knock sensors, crank sensor, cam sensors, etc. You should be able to use a lot of the original engine what year is it? AJ26 or 27?
What was the engine out of? If it ran a ZF box, you'll need to swap the drive plate.
This should be an interesting and fun thing - the bonus is a potentially great engine, just don't skimp on the parts required. I wouldn't fit anything that's doubtful, just go with new stuff as the unit cost was low. That includes waterpump
Good luck!
Good luck!
Hey Sean,
Thanks for the pointers. I plan on using the bottom end plus heads and swapping the rest as per the posted guide. The old motor is an AJ26s. The trans has a Mercedes part# so I assume it's a ZF. The drive-plate will be swapped. The car is missing the 02 sensors and Cats. I plan on making cat-less downpipes and getting new 02 sensors with mil eliminators.
Any other maintenance issues with the AJ34s that I should address while this thing is apart?
Good luck!
Good luck!
Yeah, I was a bit tired when I typed this. I do remember looking at it and seeing the MB 722 part number, which would make it a 722 trans. It's a very common series of MB transmissions. I am way too familiar with it as I have a variation of the said trans in my 911 Turbo.
http://www.6speedonline.com/forums/9...ml#post3271210
Hi, I'm out in Oswego.
AJ36 is the 4.2 litre mounted in the S type, the AJ33 is the 4.2 litre mounted in the Alum XJ while the AJ34 is the 4.2 litre mounted in the XK. The first two are nearly the same- you'll see the intercooler entry is centre fed and the intercooler roof has a concave profile.
This was done to try to improve airflow distribution. The AJ34 still uses a rear fed intercooler not dissimilar to the older AJ27 S/C units in both the X308 and X100 4 litre. It was found that there is a compromise between airflow distribution and absolute restriction across the intercooler itself.
In terms of performance all 3 variants of the 4.2 litre V8s are rated the same- the losses across the intake trunking of the AJ34 are slightly higher (140 mbar at peak power vs around 130 mbar).
I'd be interested to see whether you can fit the centre fed intercoolers into an X308 or whether it fouls something
The workshop is about 1.5 cars deep and 1.5 cars wide, but It's the ceiling height that appealed to me the most and the attic, storage space. Whoever build this place was definitively seeing eye to eye with what I'd have in mind.
I installed the lift yesterday and the concrete is solid 4-5" deep with a vapor barrier underneath. It was built in '95 and there is not one crack in the slab so it's gotta be quality.
I also got lucky with one of these right next to the workshop as the previous owner had a boat. Helps keep the rain off my toys
the AJ33 heads are a bit nasty with the lower manifold and assymetric port design- they flow only marginally better than the AJ27 but should have flowed better. If you're going to modify a cylinder head the AJ33 ports possibly have more metal to fettle.
I HATE the wrap around squish of the AJ33!
As regards the intercoolers- it's about the same- the AJ33 style has better distribution while the AJ27 has lower losses.
When doing your AJ27 top end build, I'm just interested to see if during a 'dummy build' the AJ33 style intercoolers foul the bonnet if they were to fit.
