EGR valve was replaced but CEL still on
The P0400 will be set if the vacuum in the intake isn't behaving as expected when the valve opens. So indeed it can be the valve itself or obstructed pipe, but more often air leaks in the intake system which can cause a different reading and thus evoke the P0400.
You can start with checking the stft/ltft values at idle, if you still have a good maf/o2 sensors it will show if you have a possible leak.
Added: A leak can be vey small, if you have for instance a leaky supercharger actuator that sits on the same vacuum tube as the MAP sensor will have a big effect on the readings but smaller on the stft/ltft readings.
