electric window fault
A few days ago whilst driving the drivers window started to go down on its own, after operating the switch a few times it went back to normal, however the front passenger window would not work from the drivers door switch and the passenger side rear window would go down but not up from the drivers switch all windows worked perfectley from there own switches.
Now all the windows fail to operate from the drivers switch but will work from there own switches I can hear a click inside the drivers door when trying to operate the window but nothing happens. Ihave tried a reboot but it has made no difference, any ideas please.
Finally got back to looking at the car today only to find that as well as the window fault the horn no longer works and the central locking won't work off either fob unless you unlock the boot(trunk) with the fob then the door locks will operate once off the fob and then you have to unlock the boot again. I have replaced the vehicle battery and the key fob batteries and also replaced the fuses and relays for the horn and windows but still the problems persist there does not appear to be any water damage or corrosion on any terminals that I can see.
There's several earth points with earth cables on ring connectors you can check behind each headlight frame under the bonnet. Have a look at these and clean them if required.
They have dome nuts, I think 10mm
there could be water damage of the drivers switch or drivers door module. Maybe remove the door card and inspect them, the switch is tricky to get to but it all unscrews with pozi screws. Give the connections a squirt with WD. Another suggestion is switch switches from door to door and see if faults move from door to door.
These cars are very sensitive to voltage drop and need a fully fit battery, not 12V, more like 12.5V.
Let us know how you get on.
Look at these other threads:
https://www.jaguarforums.com/forum/x...rs-door-63295/
Here is a partial extract of the information that forum member jamies xj8l post:
"After doing a HARD REBOOT you MUST reprogram the windows, this is done by rolling down the window one at a time and holding the switch foe approx. 3 seconds after you here the click in the door. Do each door in both down position and up position. This reprograms the ddm to the window parameters. In my case my ddm was bad causing the security issues. This was the biggest pain to figure out!"
Here is the weblink to his thread/posting (post#3):
Its fixed!! - Jaguar Forums - Jaguar Enthusiasts Forum
Jim Lombardi
Jim Lombardi
Loose handle
A few days ago whilst driving the drivers window started to go down on its own, after operating the switch a few times it went back to normal, however the front passenger window would not work from the drivers door switch and the passenger side rear window would go down but not up from the drivers switch all windows worked perfectly from there own switches.
Now all the windows fail to operate from the drivers switch but will work from there own switches I can hear a click inside the drivers door when trying to operate the window but nothing happens. I have tried a reboot but it has made no difference, any ideas please.
Hi
Been working away for a couple of weeks came to the car today and the horn has started to work again. Turned the key in the doorlock and held it for a few seconds and all the windows went down turned it the other way and held it and all the windows went up, tried the door switch and the windows worked once and then would not work again. Tried the trick with the key again but windows will not work off the drivers door switch I am thinking switch fault or door module fault will look for second hand parts at first to cure fault when I have found the problem will replace with new part.
99xk8guy
06-05-2023 06:28 AM
RaceDiagnostics
09-13-2015 02:22 AM
