Electrical Fault Message Yesterday
We went out in the car yesterday afternoon and it was between 10*F & 15*F outside and we're currently experiencing an inversion, therefore it's quite foggy. On my way home, the message center flashed, ELECTRICAL FAULT, for a fraction of a second. It flashed so quickly, it was comparable to subliminal advertising, but I recalled seeing ELECTRICAL and checked the owner's manual. It appears as though ELECTRICAL FAULT would have been the message, which the manual says to call Jaguar dealership service immediately.
I have an AE scan tool with the Jaguar module and I'll run a scan on it sometime today. After searching this forum, I've found very little in regard to the aforementioned message, but it seems to point towards the Body Control Module or possibly the Security Module.
Anyone ever deal with this issue before? I'm hopeful it's just a hiccup from the cold and everything is fine.
The U1135 as SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter...maybe look at the ignition switch wiring if it comes up again...
Hope this helps
Welcome to the forum. When you have time, please visit the new member area and introduce yourself. Link below:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
It would help if you provide the year and model of your car. Do you mean that you use the lighter and it blows a fuse?
I'm no expert on the subject of cell phones, but I don't see the charger drawing enough current to blow the fuse without going up in smoke, which leads me to suspect the plug somehow shorting occasionally in the socket. Do you have a GPS that you can plug in and see how that behaves? Also check the charger plug for any evidence of a burn on the metal surfaces.
philwarner
25
06-26-2021 05:43 AM
