Electrical Problem
Electrical Problem
water got into the trunk of my 1999 Jaguar XJR. Initially I lost the two brake lights (the center mounted rear window brake light continued to function), door locks, trunk release, back up lights. I checked all 5 fuse compartments and the fuses tested fine. The brake light bulbs tested fine. Over time all functions have returned except for the two rear brake lights. When pressure is applied to the brake, the Dashboard warning light indicates "Rear Bulb Failure" I switched relays and can feel the relay clicking when pressure is applied to the brake but the lights still do not come on. Any suggestions?
99xk8guy
06-05-2023 06:28 AM
