engine/abs/traction/asc - problems
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
2001 Jag X308
ABS / TRACTION / ASC WARNING LIGHTS
What next ? - Any suggestions appreciated
Have replace all 4 wheel sensors - Electrical cables look good
Removed ABS module
Re soldered 2 connections - which didn’t look dry jointed
Some rust evident between module and pump - face of pump body - it cleaned off easily
Pump seems to be working - noise when doing start up check
Pressure bled brakes - is there any indication that ABS is working ?
Started car still have all warning lights on - brakes seem to work okay and car drives changes gear and stops fine.
What now - change the complete ABS module and pump or change the wheel relucter wheels
Or scrap the car - loved the xj6 series 3 and xjs
TREV-tjcd.davis
Removed ABS module
TREV-tjcd.davis
motorcarman (08-19-2015)
sparkenzap (08-20-2015)
dragonfly777
Regional
09-08-2015 01:39 PM
