Engine Compatibility
Hi there,
I have a 99 XJ8, and I want to replace the engine. The closest in my area I have found is a 2000 XK8 with 65k. My first question would be.....Is this engine compatible ith my car? Second question is.....Do the 2000 models have problems with timing tensioners around 70k as well? The fella who wants to sell me the engine says it is compatible, but I am still leary. I have had problems with the crank shaft and had the block replaced, with no sucess from a crappy mechanic....now I just want to replace the engine and be done with it. Does anyone have any ideas or comments?
Thanks in advance for any constructive input!
Holly
Holly
Any AJ27 engine from XK/XJ will work for you.
You can use 1999 to 2003 XJ8 or 1999 to 2002 XK8.
Forget about Supercharged engines as they are too different for a direct fit.
I would still pull the cam covers to check for updated tensioners on any engine I bought and it is easier with the engine out.
bob gauff
bob gauff
Not complicated at all but requires a set of Jaguar tools to do per the Jaguar specifications.
Here are links to some DIY threads:
Cam Chain Tensioners
Help - sudden fail - Jaguar Forums - Jaguar Enthusiasts Forum
I just changed my own timing chain tensioners........ - Jaguar Forums - Jaguar Enthusiasts Forum
Ford tensioners for Jaguar??? - Jaguar Forums - Jaguar Enthusiasts Forum
Tensioners, when are they a "must replace" item? - Jaguar Forums - Jaguar Enthusiasts Forum
Timingchain.pdf
DIY ~ Jaguar 4.0 (R&R) Timing belt, Tensioners, Water Pump, etc. - Calguns.net
Cam locking tool dimensions
Welcome to Jag-lovers - Members Photo Viewing Page
Cam Chain Tensioners Cam Removal Method 2nd tensions DIY instruction FAQ - Jaguar Forums - Jaguar Enthusiasts Forum
Timingchain.pdf
OkieTim
09-08-2015 04:48 PM
