Engine Coolant Low light on but coolant level fine
A coolant leak would just cause the level to go down (and eventually trigger the warning light) and you would see it low when you open the header tank. After you have topped up the coolant, if the problem repeats (warning light comes on from time to time but you see good coolant level) and if the coolant level goes down after idling the engine for some time, this would mean that you may have a small cylinder head gasket leak which causes the combustion gasses to be pumped into the cooling system. Small head gasket leaks will keep the coolant level in the header tank high but the gas pockets will, from time to time, be purged into the header tank causing the coolant level to go down (and trigger the light). Then, more gasses will be pumped into the cooling system which will raise the coolant level in the header tank again and so on. Eventually, you will have to top-up the coolant again.
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
I have tried the following to get rid of this message:
1. Replace the tank with a new one. Still have the low coolant message.
2. Reversed the wire conection. Still have the low coolant message.
3. Unplugged the wire connection. Still have the low coolant message.
Is there any way to get rid of this message?
#28
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
innzane
08-27-2015 07:58 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
