Engine Cradle Mount MNC2360AB
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/475x195/mnc2360ab_c7d31ecbf57702da7e72d70cec2c0301f49bed7c.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/600x520/frontsus_8de652ad5d18a2260672df2fba6a9ee3e7c55163.gif)
Has anyone changed the "Engine Cradle Mount", item #4 in the diagram?
The top and outside bolts are easy to get to, but I was wondering how difficult it is to get to the two inner torx screws? And what part of the engine/subframe/frame/body do you have to jack up to remove the items? Has anyone replaced these themselves?
They're commonly referred to as the Vee Mount, and should be able to pull a few threads about it if you search that term. When I changed mine, I ended up basically supporting the engine itself from above, and lowered the subframe as much as I could which gave JUST enough room to change them out. I want to say it took us about 4-5 hours to do everything, as it was the first time I had seen them and was going slowly.
Don B (05-16-2018)
CarlzO, I did a comprehensive search, but only found one thread from several years ago from someone who replaced them and had early failure, and so then went with OEMs. I guess my biggest question is, is this a job best left to a service lift, or can it be done by a sane person using jacks and axle stands? I can't tell if the inner torx bolts are easily accessible without a lift.
Received 12,941 Likes
CK,
I've only replaced the Vee-mounts with the entire subframe removed, so I can't tell you how difficult it may be to get to those Torx screws. But since you're probably going to have to support the engine from above anyway, I would strongly recommend dropping the subframe and replacing the rear subframe pivot bushings (part 2 in the diagram in your post). If your Vee-mounts are shot, your pivot bushings probably are too, and they have a lot to do with steering precision. It would also be worth having a close look at your engine mounts...
Cheers,
Don
Cheers,
Don
BadDog
11-22-2018 12:32 PM
blk05coupe
07-30-2013 03:47 PM
