Engine cranks - no spark..2001 XJ8--Help!
CharcoalJag (03-26-2011)
Here is the big 'no start' check list: https://www.jaguarforums.com/forum/g...d-first-30792/
The FAQ sticky at the top of the XK8 forum has a world of links to threads discussing the issues suggested by the 'car won't start read first' post.
You say that you 'checked' the ECM power relay. Did you swap it with another one? Most of the relays in the car are the same.
I changed out the EMS control relay in the ENGINE MANAGEMENT FUSE BOX,the Ignition Positive Relay in the ENGINE COMPARTMENT FUSE BOX,and the EM26 Ignition coil relay.I measured 12V between terminals 1&4 on the ingnition coils with the key on( voltage from EM26).This is when I decided to change out the ECM module.
What's up all , I'm new to the forum but I've read a lot of threads pertaining to xj8. I have a 2000 xj8 vdp with over 200000 mile , had it for about two yrs never had real problems except rear u joints and wheel bearings which gave out 3 times but I think that was due to me putting 22in wheels on ,but any way I have the no start issue I've replaced spark plugs twice crank sensor and both knock sensors but still no start . I'm getting fuel as I can smell it and I checked valve don't know exact psi I recently checked for codes and got codes for all of the coils plus p1111 p1367 p1368 p1000 having a hard time believing all the coils would go out at same time also I tried the flooded car procedure but got nothing please give suggestions or any input thanks in advance
RoyLittle0
05-25-2023 02:38 AM
