Engine fail safe mode-asc trac not available
I tried searching but I can't seem to find the specific problem with my car. I was driving and suddenly the car went to safe mode with messages - engine fail safe mode and ask trac not available . I just trudge slowly home. Can someone please let me know where to start diagnosing the problem. Thanks in advance.
Reading your codes would be more productive. Cleaning your wheel speed sensors certainly won't hurt but probably won't solve the core issue.
I've had this come up intermittently with my car too. Usually goes away by turning it off and restarting. If that doesn't work, for some reason starting it in neutral seems to make it go away.
The other failsafe warning i get is trans temp to high, this when starting a cold car for the first time that day. Ghosts in the machine.
Hi, I know it's been awhile but now that I have the time to work on my car. Since the last time, I have 2 incidents of warnings on ASC and No Trac. But they were just warnings and after I cleared the code and parked in my garage. The warnings are gone. Now I want to tackle the abs module. Quick question, all the instruction does not say to remove the battery when removing the abs module. Do I have to remove the battery? I am concerned about the radio code which I do not have. Thanks Jag forum.
