Engine Failsafe mode on 2000 VDP
Hi I'm actually a new member have used this site plenty but just made an account and really need some advice.
I have had my 2000 Jag VDP for 3 years and am getting a Failsafe Engine light I went AutoZone and had codes read today.
P0171
P0102
P0121
P0172
P0174
P0175
P0112
I have had failsafe engine mode in the past but it went away for awhile.
Recently I had Restricted Performance light on and car was shaking on idle well from reading here I did the following; Cleaned the Throttle body, Cleaned MAF sensor, New air filter, and new spark plugs.
It ran perfect probably better than i was use to after all that, but know out of no where I get rough idle and engine failsafe mode and can't go over 5 to 10 mph intermittently.
Any help would be much appreciated and I enjoy doing any work myself if possible.
P0171
P0102
P0121
P0172
P0174
P0175
P0112
Be sure you have the MAF sensor connectors cleaned and correctly connected (no bent connectors or broken wires); check for air leaks in the air tube from the filter to the throttle body; clean the air bleeder valve on the throttle body; make sure the throttle valve closes and opens cleanly; remove any excess slack in the throttle cable; make sure all connectors to the throttle body are correctly seated with no bent connectors; check for broken vacuum lines to the throttle body;go buy your own OBDII tester and reset the codes; read the short term and long term trims.
If these don't work: bite the bullet and replace your secondary tensioners (I suspect the right bank may be out of time). Would have gone there first except one of the bad cylinders is #5 (first on the left bank).
Someone with more smarts and experience will be along shortly: OBTW, Googling (a verb?) these codes will tell you a lot.
