Engine got up to 249 degrees. Could this have caused Permante damage?
My engine overheated today although I turned it off before the temp gauge pegged. Prior to the overheat, the torque converter kept locking and unlocking while driving on the freeway, and would randomly not shift up a few times when driving at city speeds (revs got up to about 2500rpm on light throttle). 'High Gearbox Temp' flashed for a half second and went away. The car then overheated. Immediately after I turned off the car, I checked the coolant temp with my code reader and it was 249 degrees. I estimate the car ran this temp for about 10 seconds. No hoses blew, but my coolant cap shot some coolant out. No steam. The cooling fans shorted out because of a wire that got cut in the fan blade which caused the overheat. I already replaced the water pump, hoses, and thermostat last year.
The car is a 2000 VDP with 110k miles.
Should I be concerned about long term reliability issues from this? At what engine temp does engine damage occur on these cars? Anything to worry about for the transmission?
