Engine knocking sound / cannot identify
Old 09-01-2024, 12:27 PM
Zdicho's Avatar
Most probably I identified clicking. It comes from torque converter. I will confirm that once it will be replaced.
  #82
Old 09-01-2024, 04:15 PM
Zdicho's Avatar
Hereby videos.
File Type: avi
File Type: avi
  #83
Old 09-03-2024, 04:10 PM
Zdicho's Avatar
Originally Posted by Sean B
can you put the car in gear and make the same noise with rocking the prop? It looks like damaged splines on the transmission?
I am not sure if I understand rocking the prop. Does it mean to rock the car forward and backward?
  #84
Old 09-06-2024, 10:33 AM
RandyS's Avatar
It means to move the driveshaft back and forth to see if you can
isolate any sound it may make.
  #85
Old 09-06-2024, 05:28 PM
Received 13,291 Likes on 6,570 Posts
Hi Zdicho,
The idea is to grasp the driveshaft with your hands and try to rotate it clockwise and counterclockwise, then try to push it up and down, then side to side, then pull it forward and rearward. You're looking for excessive movement or backlash that would indicate a problem with the driveshaft center bearing or U-joint, the transmission output shaft and forward driveshaft flexible coupling (flex disc or giubo), the differential pinion bearings or rear driveshaft flexible coupling, etc.
Cheers,
Don
The following 3 users liked this post by Don B:
AD2014 (09-08-2024), EssOess (09-08-2024), Jhartz (09-07-2024)
  #86
Old 09-08-2024, 12:44 PM
Zdicho's Avatar
Thank you for hints and explanation gents!
Tomorrow arriving toque converter! Keep me fingers crossed please
  #87
Old Yesterday, 04:56 AM
Zdicho's Avatar
Used torque converter arrived but does the same kind of clicking noise... Does anybody have the possibility to access torque converter connected to the gearbox on the shelves and check if it is clicking this way?
  #88
Old Today, 10:16 AM
RandyS's Avatar
It sounds like you might be dealing with a common issue in the Jaguar XJ8,
where the torque converter can cause a ticking noise. This can often be
due to wear and tear or issues with the torque converter lockup mechanism.
If you have replaced it with a rebuilt, then it sounds like the rebuilt did not
adequately address the issue.
AbsoZed
02-12-2018 02:51 PM
Johnken
10-13-2015 08:22 PM
al_roethlisberger
04-12-2015 07:23 PM
steveinfrance
03-29-2013 03:44 PM
10-02-2006 10:12 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Quick Reply: Engine knocking sound / cannot identify
