Engine Management Fuse Box Location
Hello.
My father has a Jaguar XJ8 2003 model and is currently having some issues, the car has been sitting in his drive for a few months now as a restoration project (Was running like new when he bought it until the ABS went, after that everything else started playing up).
He has been trying to figure out where the Engine Management Fuse box is located as having called Jaguar, they didn't seem to want to know or had no idea of where it is located, having looked up on Google also he hasn't been able to find anything on it other than buyable parts, fuse boxes and or fuses.
I were hoping if someone would know where this is located on the 2003 XJ8?
Welcome to the site Sully91, it would be great to have you introduce yourself in the New Member Area and tell us a bit of yourself, your father and your Jag. https://www.jaguarforums.com/forum/n...-intro-must-5/
As for your issue, you can find a lot of useful info here for reference for his project... JagRepair.com - Jaguar Repair Information Resource (definitely save it to favorites) The Site Search has many links to pdf's and actual owner repairs. A suggestion would be to search for x308 electrical diagram, the first result should be xj 1998 Electrical Guide. Prompt that and you'll have loads of information to review because odds are you will need it later on for future reference.
