Engine Noise
Old 01-17-2018, 03:02 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
Are the OEM pulleys steel or ABS ?!
Old 01-17-2018, 06:09 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
As far as I know, first year was "plastic", then they went steel.
I checked mine some weeks ago.
I have an upgraded steel one on my tensioner, but the idler is plastic.
Still looked perfectly OK though.
Waiting for the bearings as I have a steel idler pulley waiting.
Old 01-17-2018, 06:29 PM
I'm replacing both w/ the same pulley as recommended by the forum here. I found a E-Bay seller whom apparently has a warehouse full of "OEM Exact spec" for $10 a piece. I ask him if he knows if they are steel or ABS he just goes "the same as OEM" he has great feedback. I just don't want any cheap plastic that I will be replacing again in the near future.
https://www.ebay.com/itm/122364962906
I mean it's only saving me $20 so I'll probably just go w/ the trusted/known Dayco steel pulleys.
Old 01-17-2018, 06:33 PM
ericjansen's Avatar
I am not sure if it was related to Dayco, but I read that people had problems installing one of them (think the idler) due to the difference in the OEM design between the two.
I never put the two together to compare them, but you better google a bit .
Old 01-17-2018, 06:34 PM
Highhorse's Avatar
Received 1,796 Likes on 1,318 Posts
Its been a couple years, but I'm pretty sure mine were steel.
King Charles (01-17-2018)
Old 01-17-2018, 06:36 PM
I have researched, it seems there were issues installing the bearings due to one having a lip & the other not. I haven't heard any negatives about the pulley install as a whole.
Old 01-17-2018, 06:38 PM
ericjansen's Avatar
It is easy to judge, even installed; The plastic ones have ribs to support the center, where the steel ones are flat.
  #28
Old 01-17-2018, 06:40 PM
Good call ! The EB cheapies have no ribs, I'll give them a shot thanks !
Edit :
The $20 saved = a jazzy new grill badge lol.
JLMedia
04-22-2020 02:15 AM
daboss085
06-02-2013 06:06 AM
daboss085
08-18-2012 12:42 PM
Adam Lueb
01-13-2011 05:21 PM
Quick Reply: Engine Noise
