engine noise while not running?
This one has me stumped. I started hearing whining noises from the front of the motor recently and was guessing pulley bearings were shot. But as I was checking a cracked windshield washer hose (BTW those hoses only crack after a major snowfall & the roads are full of slush) I had the ignition on, motor not running and the hear a metallic whining noise coming from the front passenger side of the engine. Almost sounds like compressor noise. What's over there that could be the culprit? AC/fan was switched off. 2003 XJR 168k miles
Thanks!
Kevin
Milwaukee, WI
Thanks!
Kevin
Milwaukee, WI
Don B (01-25-2018)
I've attached a video where you can hear the noise.
andrew lowe (01-26-2018)
rauscs
07-06-2017 05:45 PM
FaultyXJ8L!
08-15-2012 03:58 AM
