Engine Oil Cap Leak
Hi,
there is engine oil leak from the oil cap and also from the valve beside it, i checked the cap, there seem to be no wear at all, the cap looks perfect, wondering if i need to change the cap and the valve or there might be something else putting extra pressure on them. whats the common issue when there is oil leak from the cap and the valve?
I would think your part load breather is plugged and not releasing the crankcase pressure. I would check all tubes from the cam covers and make sure they are clear. On the part load breather you may need to clean out the orifice in the cam cover. It is a small hole that you can ream out will a small drill bit. Do a search for part load breather and you will find instructions.
Take a close look around the engine. Every car shipped with one on the engine. Mechanics over the years have used them and some put them back others just tossed them in their tool box.
If you can't find one on a fitting on the engine you can use a pair of needle nose pliers. Insert the pliers into the fitting and instead of squeezing the handles spread them to exert pressure on the the straps. Gently rock the fitting and it will disconnect without damage.
On my x-308 I found it on a fitting beneath the throttle body. The xk8 was inserted in the part load breather hose.
http://www.jagrepair.com/images/TSB/...ings600-03.pdf Don't feel bad, I went out and tried to get mine off with no luck. That thing has "I'm going to break" written all over it! Here's some close ups that should provide insight on the connection.
![Engine Oil Cap Leak-image-3623362725.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/136722d1475353919t-engine-oil-cap-leak-image-3623362725.jpg)
Finally got it, lightly squeezed both sides of the ring opposite the flat verticals with a pair of needlnose pliers while gently prying up on the bottom. Someone had applied RTV around the snout of mine which is why it was reluctant.
![Engine Oil Cap Leak-image-2781409479.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/136721d1475353909t-engine-oil-cap-leak-image-2781409479.jpg)
Hi,
al_roethlisberger
05-29-2021 05:43 PM
aholbro1
02-14-2021 01:51 PM
silversurfer1221
10-08-2017 10:08 AM
