Engine oil help!!!
Engine oil help!!!
I recently changed the oil on my 2001 VDP (Mobil 1 5w30 mineral and a liter/quart of Lucas) and the motor developed a tiny tapping noise which is gone after 2-3 minutes of warm up. I remember reading somewhere that a different/thicker oil grade might take care of the tapping noise. I live in NW Pennsylvania (cold long winters) and I'd like to find out what kind of oil should I use to get rid of the tapping noise at start up. I don't want to switch to synthetic oil due to worries about future gaskets leaks. Thanks
Received 2,263 Likes
Received 2,191 Likes
i guess you havent read the ssm/jtb on useing bg44 gas tank additive then. No more than 2 times per 15k miles
As far as Lucas goes, just say no.
As to the oil itself, you may want to try a 10W40 or a diesel formulated 15W40 such as Castrol or Shell. Both of these weights would still be fine in PA.
If you do not see an improvement you should definitely consider whether something is wrong that oil will not fix. Of course there is always the question of whether you have addressed the upper cam tensioner weaknesses.
It might take a change or two to get rid of the Lucas.
Yep, it could also be the secondary tensioners. Get this seen to ASAP.
On our fleet cars we used to see some difference years ago when 5w oil was rare and the service people only had the 10w. Everything was 10/40 and it was too thick for the Ford overhead V6's at start up.
We always use the recommended oil -- even the 5/20 has proven to be fine.
The additive you put in may be making the oil too thick and limiting its ability to flow to the valves at startup.. I would change it out since you preciously had no problem
The Lucas lubrication products, in general, are all thickeners. That is why the tapping goes away after warm up.
Of course, since you just did an oil change, you are reluctant to hear the message because it is going to cost money to replace the fresh oil.
But, there is no way around it. Lucas products, and in particular the power steering additive, are bad news in the cold. Winter is coming and you are in PA.
If you want a specific recommendation, the 5W40 Shell Rotella T6 Synthetic mentioned above is an excellent oil for your conditions. Another one is the 15W40 Shell Rotella T5 conventional.
