Engine oil overfilled, spark plugs wet, hard rattle
Good morning Saturday, brothers. Supposed to be a routine oil change. My machanic over filled the engine oil and spark plugs got wet with oil. Check engine light is not just on but flashing also the restricted performance warning light. Engine rattles hard in cold start.
he took off the plugs and cleaned with air gun,but it's not really helping.Please advise or share
Re: Engine oil, there is a dipstick and drain plug to correct the level, has this been done? I have seen an over fill cause an event by over pressurizing the timing chain tensioners, they crack and fail leading to.....
Rattle sounds like a timing chain issue = codes would possibly be multiple miss-fires.
My advice, Do Not Start the Engine until you have removed a cam cover and inspected the timing.
Vincent, please don't run the engine until you've got a look at what's causing the rattle, it's like playing Russian roulette with every startup on your engine, the next one could be valves meeting pistons.
Daim (02-07-2018)
arath25
09-01-2014 07:23 AM
prodigy215
10-24-2013 01:22 PM
