engine squeak + vibration
Hi Jag Enthusiasts,
I just acquired a 2003 XJ8 VDP with 134,000 miles on it. I've had it for two days and have a few problems to research. I can't seem to search the forums - it gives me a database error. I am hoping for some advice.
1. On a cold start, the engine squeals a little bit (sounds like a squeaky pulley). Once the engine is about 1/2 way to operating temperature, the squeak only happens under acceleration. Once to full operating temperature, it goes away completely. Thoughts on what this could be or how to troubleshoot?
2. At idle (whether cold or warm), the engine puts a very slight vibration through the car. It is not enough to shake my arm hairs as I grip the steering wheel, but it is enough to rattle the console/dash. Is this something like a bad engine mount? Or do you think it is over due for spark plugs? Or should I just chalk it up to "its an old, high-mileage Jag"?
3. The car's front suspension seems to make a hollow-sounding thud in the floor when hitting bumps. The ride and handling are amazing, and service records show that shocks have been replaced within the last 30K miles, so I am wondering if this is just bushings (of some sort) gone bad? Can I look under the car and see this for myself?
4. Plastic cupholder rings are broke. Anyone know how I should deal with this?
5. My radio antenna will only motor half way down. It then stops. It seems like this might just need some graphite to lubricate it or something? Any recommendations on how to care for that?
6. I only have 1 key and no remotes. Is this something I have to get at the dealer? Or does anyone know of a cheaper alternative?
7. Last little thing: the climate control screen (that displays your temperature setting - like 77 degrees) is only lit on the left side at night. I guess a bulb is out? Anyone know if these are easy to replace? Or is it something stupid, like you have to replace the entire instrument panel?
Thanks for any thoughts you might have to any of these.
Chris
Chris
Hi Jag Enthusiasts,
Chris
Chris
1. Sounds like it needs a new accessory belt, but with noises it's always a guess until you can post the sound on here, for example record it on your phone and upload the video to photobucket/youtube then post it's link to here so we can assess it.
2 & 3 - sound very much like engine mounts, it's a common problem, not a big job to change them for new, the issue is a split and the engine moves up and down, you can brake test one side my putting the car in gear with the hood raised and raise the revs against the brake to see if the engine lifts, rough and ready test. Another sign is weeping down the inner chassis legs around and below the mounts, best to check with a flashlight on a lift....
4. Very common problem, there's fixes so search the forum, or buy a second hand unit...
5. Antenna needs replacing - same as a volvo part, the plastic lift/ close whip could be snapped inside, they're a $10 part and super easy to change, again a sticky is on here I think by member David N on changing it out.
6. Keys and remotes are very well covered on here, all the options too, dealer is expensive for keys, they're a Tibb and can be bought new uncut from ebay.co.uk sellers. Programming is a different matter, you'll need to find a locksmith with the right gear to clone it, or dealer. If and when you get the search option working read through for your own option. The remotes I think are 315Mhz and sometimes can be bought on ebay, programming to the car is a 5 minute job again covered on the forum.
7. is indeed a simple bulb out - to get at it you'll need to remove the gear selector ring and 'ski slope' wood trim, then the climate pack. The bulb can be bought from the dealer a T10 twist lock type.
Hope the mods bump your membership to 'full' - then you can crack on with fixing the niggles.
Hope that helps and good luck with the new ride.
Hi Jag Enthusiasts,
Chris
Chris
Another thing... if you decide to change bulbs think of replacing them with LED bulbs - both on A/C dash and the bulbs for the instrument cluster. It will look better, believe me
The bulb types are 194 type and T10.
If you want to remove the instrument cluster here is FAQ on how do that: https://www.jaguarforums.com/forum/x...r-i-faq-57772/
Welcome to the forum,Chris. If you have not already done so, visit the new member area and introduce yourself. You will find some useful info there. You will not be able to download pdf's until you have 10 posts and been a member for 3 days, if I remember correctly, and that may apply to the search also, don't recall.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
The hollow thunk could be sway bar bushings. Check the links, also. For keys, you are pretty much stuck with the dealer, although some indy's can program. It is expensive.
The squeak can also be the tensioner pulley-I had squeaks from both belt pulleys (supercharger tensioner pulley on XJR models as well as main serpentine belt tensioner pulley). The grease dries out & the bearing races run dry until they heat up & some is redistributed-hence they often quieten down on a hot engine.
Antenna is easy to fix-it's usually just the centre moving section & nylon cable that's stuck or worn out. It's an easy procedure to replace it & quite cheap as you don't need to replace the whole antenna motor assembly.
The failed bulb is easy to replace, although it may be a bit fiddly as you need to remove the gear selector surround, the main 'ski slope' trim piece & then undo the screws to wiggle the stereo head unit forward & then wiggle the climate control panel out.
You'll probably need to move the gear selector lever down into the 'D' position to make access space, and it's worth putting a thick cloth over the gear selector lettering panel in case anything scratches it when you remove stuff...
Wow, thanks everyone. This is by far a friendlier forum than I belonged to for the BMW I used to have. You guys rock.
I will set to work on this list ASAP.
One quick followup - I noticed this morning that the slight engine vibration I referred to gets a bit more pronounced when the A/C compressor engages. I'm not sure if that clue helps in diagnosis or not. It seems like this would make sense if I had a belt tensioner problem, no?
Dumb question: If the 'thud' over bumps is merely sway bar bushings, I've read on the forums that those are cheap and a possible DIY item. Problem is, I have no idea what to look for. I thought a sway bar was a rod under the hood, running across the top of the engine, connected to the wheel wells on either side. But I don't think I have one of those (if I remember the engine bay correctly). Is it possible to describe where are those located, and can I see their condition by just looking at them?
Thanks,
Chris
Thanks,
Chris
Part number#MNC7500AB I've ordered dozens of them, never been asked by the main dealer parts guy I've known for 20+ years if it's S/C or not.
It will weep if goosed.
Anti roll bar bushes look like below. 10 minute job to fit if you can swing a spanner.
There's a ring of rubber between the inner and outer parts of the pulley that dampen engine vibrations, it can crack and lead to the symptoms D mentions.
The part is unavailable from Jaguar, at least the supercharger version, but can be fixed by an American company that replace the rubber.
OkieTim
09-08-2015 04:48 PM
