Engine stalled
Maybe we both have ex girlfriends visiting us with a cup of sugar.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Unfortunately, that's my first guess. I already lost my first pump a couple months ago (Swapped the Wires to keep it running temporarily), and now I'm thinking the second is on it's way out. I don't know the problem with the first one. It runs, but when I pull the Fuel Level Sensor and look inside, I can see the fuel spraying around inside there, almost like a line broke, but I cannot see anything loose. It's like it's blowing underneath the pump. I'm wondering if the second pump is doing the same thing now.
I really hate to have to tackle these again as I just did them barely over a year ago. It's a PIA. When I did it back then, the tank was spotless, not even a small amount of debris anywhere. I checked and double checked the connections before putting the tank back in because it was such a hassle to get out.
Code Scan came up clean, P1111
I'll clean the throttle body and breather again and see if that helps the missing and cutting out, although, it has not been that long ago that I did that.
OkieTim
09-08-2015 04:48 PM
