engine stalled at 65mph. Help.
Recall #303-S514 dealt with throttle body recall for this exact issue; if not already done, will be done by Jag dealer free of charge - have a dealer check your VIN in their computer to verify the recall status.
________
1999 XJR
________
1999 XJR
Received 2,190 Likes
THE MOSTY COMMON ESPECIALLY IF YOU TOOK YOUR FOOT OFF THE GAS AND IT DIED, IS A PLUGGED PART LOAD BREATHER( PLASTIC HOSE CONNETING TO TOP FRONT OF DRIVERS CAM COVER, DISC. LINE AND USING A SMALL 1/16" DRILL BIT BY HAND PUSH THROUGH AND UNPLUG. OIL DEPOSITS BUILD UP AND PLUG THE OPENING CAUSING STALLING, I CLEAN THIS, AND THROTTLE BODY ON AN INJECTION SYSTEM FLUSH OR AS NEEDED.
That sounds like a throttle position switch fault, which means a new throttle body. You should have fault codes stored as a result of this event, so you need a scanner to read them. There was a recall involving replacement/ reprogramming of throttle bodies that your car was eligible for: there should be a white sticker with that information on the top radiator mounting panel under the hood which was applied after this recall work had been performed.. If not, consult your dealer to see if your car has any outstanding recalls.
