Engine starting problem
Thanks everyone for your comments and suggestions. I learned a lot from them. Finally was able to trace the problem to a bad fuse in the right rear panel. Replaced the fuse, jumped the battery, which I think was drained from all the efforts to start the engine, and the engine started. I've replaced the battery, which was quite old. Up and running again, happily driving my XJ8. Thanks again.
RJ237 (07-24-2015)
Which fuse?
I believe I should have said "left" rear fuse panel; i.e., the one behind the driver's seat. Fuse replaced was #6, which provides voltage to something called the "reader exciter ECM," which I believe is security-related? Interestingly (to me), I read somewhere in another forum today that this fuse also controls power to the clock in the center console, which explains why the clock stopped (clock is running again). Thanks.
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
1964Daimler
09-02-2015 11:41 PM
