engine swap
engine swap
hello, I have a 2002 xjr with a bad engine the # 1 and 2 cyl have gone south. Pulled the engine and found the crank to be in bad shape and the webbing on the block gone where the connecting rods took it out.
I have a 1999 xjr with a good engine that I've been using as a parts car, my question is the block the same on both engines?
thanks
thanks
Carnival Kid (04-01-2019)
The blocks are probably the same except that the 1999 block has Nikasil liners which may require different piston rings. Of course, if you are transplanting the 1999 block complete with its pistons, then you are fine in this respect. Someone will hopefully be able to inform whether there any other differences in the engine blocks only.
texmanmoore
07-01-2008 10:53 PM
