Engine Warning Light
Hi,
I've a 2001 Sovereign 4ltr and the Amber Engine Warning light has just come on. Took it to a dealer and they reckon it's either the top or bottom exhaust sensor or whatever those sensors control. They want the car for 2-3 days in case I need parts they haven't got in stock. I live in Tenerife but I'm back in the UK from 20th to 30th August. Any idea what these sensors cost and are they easy to replace as I could try to get them while I'm in the UK. Also anyone know what the sensors monitor.
Regards,
dave
Regards,
dave
They are the oxygen sensors, or O2 sensors. There are 4 of them. The upstream (first from the exhaust) and the downstream (2 each). It can run you into some money if a shop is replacing them. You can buy a code reader that will let you diagnose these types of issues - with the help of the forum and the archives.
Here are some trouble code excepts. "A bank" is right side "upstream" means the first one back from the exhaust manifold.
P0131 - HO2S sense circuit low current –
A bank, upstream (1)
P0132 - HO2S sense circuit high current –
These codes are a starting point for diagnosis.
If you do have a bad O2 sensor, it may cause the car to run rough and get poor gas
mileage. Also, where I live, it won't pass emissions inspection. I'm not sure about the regular safety inspection, but a check engine light is not good. Do they even have inspections in Tenerife ?
Dave:
Did they read the codes from the car by attaching a scanner to the data port on the inside of the car, or did they tell you that "off the cuff"? There are many many causes for a CEL, and from you rdescription, they simply recited one of the many causes.
And... I agree with Jim - if you want ot participate in decisions on a car's maintenance, you must get a code reader so youi know what the car thinks is wrong!
All the more reason you NEED a scanner:
Look here:
https://www.jaguarforums.com/forum/x...scanner-99855/
Look here:
Dave have you, or anyone else, now had any experience of the Tenerife Jaguar main dealer? I'm thinking of using them.
Since bringing a Jag here to Tenerife I've used two different independent garages in the south for minor things. They were recommended on Tenerife forums but they weren't that good. So I'm thinking of paying a bit more and using the Jaguar dealer.
Hi Joe
They are good and they do have someone who speaks English if you need it. You'll find the costs are very good compared with what you pay in the UK.
I have also used "Taller Aleman Heiko" in Guagacho for general servicing etc and he is also good and a cheaper alternative. Tel No 922 734316.
I'm of to UK today for 2 weeks so best of luck
Regards
Dave
Regards
Dave
X_Type_South_Africa
12-09-2015 05:37 PM
Aranon
09-01-2015 01:00 PM
