error 1336
You need to post more information, like is the car running, and if so, what are the symptoms.
Try using the search function for code P1336. It appears to be a mis-match between the Crankshaft sensor and camshaft sensor in some cases. If the upper chain tensioners were replaced, it may have been put together wrong.
I'm just guessing, here. Without more info it's unlikely the forum members will be able to help.
jimforrest (uk)
02-28-2019 06:42 PM
Collector1
09-28-2015 03:52 AM
