Error codes
The following 2 users liked this post by GGG:
A.J.P (08-19-2018),
motorcarman (08-18-2018)
xjfourty (08-20-2018)
Or C1095 or Front ABS link harness fault or??
C codes are NOT P codes!!
The engine module (P codes) doesn't really care about the Chassis (C codes) (except as a network info transfer) and will not normally log a C code in the ECM.
You will need a specific diagnostic tool to read the codes from other modules in the network. The ECM is not your problem, the ABS module is your concern.
bob
bob
