Evap - p0455
Evap - p0455
Infrequent P0455 now comes back soon after cleared. Replaced fuel cap. Put up on rack, none of the hoses are cracked or brittle, but a thin layer or dried hose sloughed off. It is the two cannister running loss system.
Am I correct that the canister close valve is normally open (open when not energized)?
Am I correct that the EVAP canister purge valve is normally closed (closed when not energized)?
Going to start by checking valves.
If valves check out, going to smoke test (cigar and pump). Has anyone done this? From gas tank or from hoses under body?
Not seeing replacement rubber hoses for sale. If replace hoses, what kind of generic hose can I buy the foot?
I had this same issue after replacing all the other causes of the 455. Those actions minimized the reappearance of the 455, but maybe after 6-8 months it would popup. After replacing this, its now been 3 yrs and no 455.
Just replace the valve, its cheap and takes about 20 minutes....most of it getting under the car. You'll see more of the condition of your hosing then. Its behind the RR wheel section.
motorcarman (09-07-2021)
The following 3 users liked this post by pcolapacker:
jagstein
02-25-2010 11:56 PM
