Exhaust camshaft won't come out !
Did you detach the sprocket from the camshaft? If not and if the chain is under tension, this tension will pull/skew the camshaft slightly when the cam caps are removed. This skew may cause jamming of the camshaft's front journal onto the head casting (at the front bearing) as the front camshaft journal has "side walls" that engage with very tight tolerance.
Don B (02-12-2021)
Don B (02-12-2021)
Okay after installing the cam caps I turned the engine again the flat cam lobe face up i sprayed penetrating oil on all over the cam left it for about 2 hours . Then I removed the caps it was like stuck again but removable installed 3rd generation tensioner to my eye the exhaust camshaft have slight Bent but I'm not really sure installed everything back and start engine I would say there's slight more engine vibration than before when In neutral below 600rpm .
motorcarman (02-13-2021)
The cams are CAST and like RJ237 said..........The would likely BREAK before they would bend much.
The cam does NOT need to be in the timed position if you are going to 'zip-tie' the chain/sprocket.
The cam can be anywhere because it will be locked to the chain with the sprocket TIGHT.
time ist easy to clean the oil screen?
anthonyisd3ad
11-23-2011 03:59 PM
