Fail Safe caused by TPS?
Old 02-22-2008 | 01:37 AM
CarBizIndio's Avatar
Default Fail Safe caused by TPS?
The 1999 Jag I have has no check engine light on. It will go in to fail safe mode if more then %75 throttle is applied. I think it is the TPS because I can trigger fail safe mode with the vehicle turned off and key on while I depress the throttle. My question iswhat is the most common link to the fail safe problem? Andhow often do the tps sensor's go bad and also is there a factory repair manual I can down load off the Internet for free?
Old 02-22-2008 | 01:44 PM
Default RE: Fail Safe caused by TPS?
I checked TPS % with the engine off and key on and it seemed to be fluctuating from 2% up to 8% so I think I'll change the sensor and cross my fingers.
Old 02-22-2008 | 04:30 PM
FactoryJaguarTech's Avatar
Be careful as TPS is a calibrated part to your throttle body. Not normally serviced seperatly. Did you have codes? If fail safe engien mode is illuminated, it will give you a code.
Old 02-22-2008 | 06:20 PM
Well I didn't want to hear about the calibration thing. I try to avoid the dealer as much as possible, can a snap on scanner calibrate the tps? I have no check engine light on so I didn't search for a code. Does the computer have to get flashed to calibrate the computer or is there a easy procedure?
Old 02-22-2008 | 07:40 PM
jag_genius's Avatar
you might need a throttle body.. i think snap on will get a code. but no description
Old 02-22-2008 | 07:41 PM
I dont mean a calibration via software. It is bolted to the throttle body in a set position.
Just because CEL is not on doesnt mean there will be no codes. If you have a snapon scan tool you may be able to read codes. Try and read them when failsafe engine mode is showing on the cluster. Do not turn key off, just read the codes. Let me know what they are.
Old 02-22-2008 | 07:50 PM
Dealer said I cant get the tps by its self I have to get the whole throttle body. Looks like I'm going to send it to the dealer for a diagnosis before I spend the big bucks.
Old 02-22-2008 | 07:51 PM
If I get a used throttle body is there any programing involved?
Old 02-22-2008 | 08:01 PM
Codes
P0121
Pending
P0121
P1000
P1637
Sounds like a throttle body to me. What's your thoughts?
Thanks.
Old 02-22-2008 | 08:12 PM
jag_genius's Avatar
well the throttle body 's are like 2000.00-2500.00
Old 02-22-2008 | 08:14 PM
Genius you still have that throttle body in your store?
Old 02-22-2008 | 08:16 PM
jag_genius's Avatar
no but i can get them. what year is the car? old style throttle body or new?
I located a used throttle body plus intake for $400. Or supercharger and I'm assuming it comes with the throttle body for $750 =). What's involved with putting theSC on this engine? Is the engine harness the same just with a different ECU for the SC?
Old 02-22-2008 | 08:19 PM
You dont want to retrofit it. Alot of work.
Genius it is a 1999 i think.
I would advise againt buying a used throttle body. If Genius can get one for you, I would buy that.
Old 02-22-2008 | 08:21 PM
1999 Vanden plas XJ8 4.0
Old 02-22-2008 | 08:30 PM
jag_genius's Avatar
im assuming vacuum assist?
Old 02-23-2008 | 12:46 AM
I'll check tomarrow. Is a 2003TB the newest used TB that will interchange on my 1999?
Old 02-23-2008 | 07:44 AM
It may not. I forget when they chenged them. Can you post a picture of it?
Old 02-23-2008 | 12:33 PM
http://i69.photobucket.com/albums/i7...dio/jagtb2.jpg
http://i69.photobucket.com/albums/i7...dio/jagtb1.jpg
From the looks of the bolts for the throttle cable bracket it has been taken apart once.
Old 02-23-2008 | 01:22 PM
I disconnected the battery, and then took it for a drive at WOT and no fail safe. I wonder how long this will last.
