Fail Safe/Reduced Performance at random unexpected times
Every now and again, out of nowhere, sometimes while sitting at a traffic light, sometimes while cruising along, all of a sudden I'll get the FAIL SAFE warning and reduced performance.
I pull over, shut down, restart and it goes away. Minor inconvenience but I'd like to figure out why it happens at all.
Any ideas or suggestions?
Steve,
Hard to say what you have going on and I have no idea the year and model of your car, please add it to your post. I would also recommend that you take your car to a place (I have no idea what state or country you live in) and get the codes from your OBD II. When you get the codes write them down so that you can tell us what you have. We want to help but to give you advice now without all the information is just a shot in the dark.
my bad for incomplete info: the car is a 2000 XJ8 - 117K miles
Will have to see if I can get the codes read without spending an arm and a leg. My recollection is in California (where I am) there's some kind of rule that auto parts stores can't read codes or something goofy like that.
Will codes show up when there's no current warning or restricted performance?
If your check engine light has ever come one during one of these events, the codes will be stored and your local large parts store can read them... if the CEL has not come on, you're not going to have codes.
Usually when reduced performance mode comes on, other error messages scroll across the display - gearbox fault, asc fault, trac control error, etc. Have you seen any of these also?
I had the same intermittent problem for several months (especially when wet or moist outside), with no CEL... eventually the period between events decreased to minutes and finally I fineally got a CEL - which allowed me to read the codes and zero in on a mis-reading from the Throttle Positon Sensor - turned out to be moisture in the TPS connector - cleaning the connector pins and lubing the connector's o-ring with dielectric grease to prevent future moisture incursion has cured the problem for over a year now.
scottatl
09-04-2015 08:08 PM
