Failsafe engine mode and error codes
Should it always throw a code when it drops into failsafe engine mode?
The light and message came on on the way to work today. No symptoms that I can see. When I got in I put my code reader on it (before turning the engine off): the reader is denying any stored or pending codes. Turning the engine off and back on cleared the failsafe mode.
I'm now left with the question of whether it's the car imagining things, Jag being unhelpful, or my cheap and cheerful code reader not reading what the car's telling it. None of which is a particularly attractive option....
My code reader (OBDCOM) would not read a code for failsafe mode either. Each time i restarted the car the failsafe mode was gone and would return while driving. No change to engine performance but the cruise control would become disabled. My problem turned out to be the brake switch ( thank you Forum members for the info) and I was able to fix it just by spraying some WD-40 into the switch at the plunger. No failsafe mode since then
Distraxi (12-19-2012)
The problem is that your OBD reader only reads 'P' codes (powertrain) and other things can set codes you can't see. Some (like ABS and airbags) will trigger warnings but others won't.
Check your battery is good - that can cause odd behaviour - and let us know what happens.
If you haven't already download JTIS https://www.jaguarforums.com/forum/x...archive-65998/
for a goldmine of info.
Good luck!
Thanks guys, this forum's great.
If contact cleaner doesn't fix it there's a sticky on changing the switch which is a pig of a job
https://www.jaguarforums.com/forum/x...ics-faq-37758/
with a follow up
https://www.jaguarforums.com/forum/x...allenge-83605/
Someone fixed their switch by bending one of the microswitch levers so both switches operated synchronously but I can't find the post.
with a follow up
