fans still work when i turn the ac off
I have a jaguar xj8 and when i turn on the ac the fans start to work (as expected) , then when i turn off the ac (even immediately) the fans will not stop working until i turn off the engine (note: the car is still cold). I turn off the engine and set the key to ON and the fans start to work again. The fans will not stop working unless i let the engine off for about 10 mins. Any ideas?
Note: Also when i set the ac to circulate air from inside the car in about a minute it sets by itself the ac to insert air from outside. is that normal???
Sometimes mine stays on recirc after a start and stop and sometimes it does not. Pushing and holding the recirc button is now part of my start up procedure.
Vector
Wow, learned a new Jag trick about holding down the recirc button - mine shuts off after a random amount of time, typically at least 10 minutes but sometimes it just stays on - never knew why but figured it was a sensor somewhere that thinks I want that (I don't - it often does it just when I'm behind a dirty-diesel...)
Vector
silversurfer1221
27
09-27-2022 02:06 PM
Alli Quinninho
12-22-2020 03:00 AM
06-28-2006 03:53 AM
