Fault messages
Fault messages
My car is an XJR and there are some fault messages. Suspension fault and ABS/traction/ASC. I've unplugged the cable to the suspension module and there is no suspension fault message anymore. When I unplug the cables to the ABS module the fault messages are still there. Could it still be something wrong with the ABS module.?
Please list the year along with the type (as you show)...just put it in your signature....trust us, it makes a difference when inquiring on issues. Also, get us the Codes, that helps dial it in and not all codes exactly state the issue and are related to another issue.
First, you'll want to bookmark this site... JagRepair.com - Jaguar Repair Information Resource
From that site you'll find these using the Site Search....I put in "X308 ABS" module and you'll get a list of responses.
This one is older and most anyone does the second link, but this one also mentions the caliper sensors... http://www.jagrepair.com/images/Auto...aul%20Bush.pdf
Here's the procedure I did,... JagRepair.com - Jaguar Repair Information Resource ...but I used a black plastic plug, drilled to size and sealed the lip with silicone. It came in handy a few years later when my soldering came loose again. All I had to do was pull that plug, solder again and I was on my way.
mcm97
09-22-2014 09:08 PM
