Faulty Brake Pedal Switch?
Does Jaguar publish the specs for bench testing the subject switch P/N LNB6420BB? I've been experiencing the Failsafe Engine Mode warning (DTC P1571) with concurrent loss of cruise control. The fault doesn't trip if I drive with the cruise control disabled. I've had the switch out and appear to get a much higher resistance on the center two pins than the outer two when the two small push button switches are depressed. Suggestions?
roberthornsey (02-09-2016)
roberthornsey (02-11-2016)
IIRC, and it has been awhile, there are two identical microswitches in that assembly. In my case, one of them was "lazy" when opening and closing. Using a soldering iron, I swapped them and the problem went away.
I think one is used for the brake lights and the other goes to the cruise. It should be in the schematic documentation.
-Mike
-Mike
Just ordered a replacement switch assembly. Hopefully that corrects the problem? Or at least I'll have something to compare resistances. As an aside I've noticed, since I turned off the cruise control, my passenger side mirror no longer drives into the lower stop whenever I used the key fob to unlock the doors. Maybe the new switch will fix that too!
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
