Fixed my ABS/Trac error in an odd way :)
Received 2,263 Likes
As the pads wore down to near nothing, the fluid level went down. I topped it off the the full level.
As I said in my first post "where someone repeats my error of leaving the brake fluid level too high"
Yes, when the new pads were installed, it pushed the pistons back on all 4 corners, a lot. The fact that this then caused an overfull situation is then not surprising, or even uncommon, as you said, so why you surprised that this happened then?
The point of my post was that it fixed my ABS light problem for good. To this day that car has had zero abs light issues. That was the main point of my post, my motivation was to be helpful to this community. Given a few others have reported this odd fix worked for them, then this post was helpful. So, to that end, I am happy I posted it.
What is the motivation for your post?
Question: Are you still using the same fluid that was installed from the factory? ? Because that would be (insert word here)
Adding fluid with partially worn pads is not required. The reservoir contains enough fluid to accommodate four sets of fully worn pads and still be within acceptable limits.
jimlombardi (04-19-2014)
aholbro1
08-05-2021 05:02 AM
scooternva
19
10-27-2015 02:14 PM
