Flat Battery.
There are threads on here explaining how to:
What I recall is removing license plate, where you'll see a hole. You then stick something like an icepick in the hole and wiggle and push until the boot pops. My memory is not the greatest, so find the threads. I wish you success................ Jim
If you open the bonnet, on the drivers side ( RHD ) there is a rubber cap on the false bulkhead, pull this off the stud and you can put a positive jump lead to it, the negative jump lead to the chassis and this will let you open the boot. DO NOT try to jump start the car this way.
Lear45 (08-09-2014)
