flat battery
when i went to my car the battery was so flat that boot lid wouldnt even pop on fob, had to use the key, and now the car wont start, engine turns over but wont fire, do i need to reset anything as the battery was so flat, eg ecu or alarm? and if i do how do you do it?
thanks in advance for any advice
I assume, but you didn't say, that you charged the battery.
Everything will probably reset just fine but it doesn't hurt to completely reboot all systems by removing the negative cable at the battery and touching it to the positive battery terminal. That will completely drain all the little left over electrons and completely restart everything.
shootingbrake
09-23-2015 10:54 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Dickie_L_J_O
09-13-2015 07:44 AM
