Flickering dash lights and limp mode
Good update, does it click when you depress the brake pedal? Some have removed the brake pedal switch and cleaned the switches with contact cleaner, others replace the interlock solenoid on the side of the selector under the ski slope, you've to find out which!
Also can you select all gears without issue once unlocked? (selector/cable alignment Q)
