Floor Jack Question X308
I've used the same old FJ for years on a variety of my recent Jaguars (XJ40, X300, X308, XK8, XK) and other vehicles. Doesn't look pretty any more but it's reliable!
It has a similar problem of almost no movement on the lever with the vehicles on level ground.
I get over this by jacking under each spring pan in turn and standing the road wheel on a short length of 3 inch by 7 inch timer joist offcut to raise the front of the vehicle. Very quick and it means I can then easily use the FJ under the cross member etc.
The following 4 users liked this post by GGG:
Thanks Graham,
For those of us who are not certain exactly where the spring pan is, could you post a pix perhaps with an arrow?
I can see from your photo it is behind the wheel.
Part #3 in this drawing
Part no. CBC7278 | Spring pan parts from Jaguar Heritage Parts UK
Would still like to see a photo showing exactly where you place the FJ saddle.That spring pan does not look flat.
FS[SouthEast]: Mid range Scissor Lift
Chuck Schexnayder
01-13-2016 06:38 PM
philwarner
12-14-2015 10:02 AM
