FM Audio Transmitter problems.
Hi all,
For years i've been using these cigar plug in bluetooth - FM transmitters that allow you to play your phone through the cars speakers. All very rudimentary stuff, but for some reason they won't work in this Jag.
Do other people have them in their X308? Is there an issue with using them that i can't fathom? It's just your typical ebay chinese unit (although i have several different ones), they all work fine in other cars, just tune the stereo into the correct frequency and voila! But in the Jag there's just static and the occasional vague ghost as i cycle through the full FM band.
Help, before i take a hammer to it...
Cheers!
Cheers!
The Jag does struggle to pick up radio stations at the best of times, is there possibly a common issue with signal reception? Perhaps a poor connection? I know it's only a bit of coax from head unit to aerial, but i'm clutching at straws.
Is your radio working fine without the FM transmitter? I use one and it even works or the aerial is not up. I can use both cigarette lighter ports without an issue. Do you have tried it using manual search mode?
The connections to the radio itself are fine as i have it out of the dashboard already.
JayW (06-24-2020)
motorcarman (06-25-2020)
Oddman
01-08-2019 02:21 PM
